how to wire 6 10s
ZachG
I need a wiring diagram to wire 6 svc4 10s.
Can anyone link me to a page or show me one? I would like to see if its possible for 2ohms or see what I can wire them to
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
6 SVC drivers with Voice Coils in Parallel:
All woofer (+) to the amp (+). All woofer (-) to the amp (-) connections.
4 Ohm Subwoofers: 0.67 Ohm
Ehh is there anything else I can wire to... Or what would it be if I ran 3 to a amp
Series them in pairs (3 pairs - 8 ohms per pair), then parallel the 3 pairs to get 2.67 ohms.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
If you are really doing this a 0.5 ohm stable capable amp will fo great, many 1 ohm stable Sundown amps will work perfectly with 0.7 ohm.
I think that would be your best bet.
Rockford wiring diagram says I can do 3 svc4 subs at 1.34ohm so all I need is 2 1ohm stable amps right
& if you saw my other post with this new build I'm focusing on low wattage and lots of cone area and motor force
if you do two amps then you need to make sure that they are strappable
just curious, how much power do you want to run?
if you are asking this question on here I don't feel you need to run 6 subs or it would just be a waste of time. are you building a box for them? how much power too? usually when people do bigger builds they have done some research before jumping right in. this is kinda basic. not trying to be a dick but are you really prepared to do a build with 6 subs?
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
The point of this is to stay under 1k rms.
& If I run 2 amps I will do 3 subs in a seperate chamber then the others and get a second set of rcas
No you dont, you can just gain match.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
