Sundown SAZ 3000D Half-Dead
OrionStang
wonder if you unsolder those 2 8g runs and resolder new ones if that'll fix your issue, some people acually upgrade those wires to 1/0 if they have the room and see like a 15-20% output increase in clampped numbers, i had a stetsom 7k2d that was "modded" like this, did like 9.8k clampped after the guy did it
1/0 is pushing it cramped for space in there might be able to get away with 4 gauge
for this amp you prolly cant do 1/0 but ive seen it done with others, 4g prolly though
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
All the rca wiring connections look good. The gain pot and connection isn't loose. I think it may be the big wires, one is output and one is ground, so if they're bad, could be the problem. I will not be attempting the repair however LOL
SMD Super Seller
My Feedback Thread
ya i def think the 8g wire needs to be upgraded to like 4g...
*** 1991 Turbo Walled Civic 400whp @ 20psi ***
- JVC KDS88BT Headunit - 4 15" Fi BTL N2 Fully Loaded Subs - 1 SD16kD Amp - 14.5ft^3 Wall Tuned to 37hz with 202in^2 of port - Mechman 220a HO Alternator - 6 XS Power D3100 Batteries - Copper Buss bars - 2 Runs of 4/0 Welding Cable - Big 3 - Stinger Digital Volt Meter
Burp outlaw in the kick: 158.9db
Music: 157.5db
Sealed on the dash: 157db
- SPL Labs Rep for Missouri -
Someone said it was due to the RCA's internally, but it might have been due I had an rca end brake off it's grounding strap inside the RCA. So it was intermittently grounding, and not grounding. So guess I'll either send it to Db-r or someone else. Stuff like this happens. Name of the game.
formerly known as Blue86f150
its a 4th order just because its tuned in the 40z doesnt mean it wont reach down and jiggle your balls at sub 30 hz frequencies.
Regardless if they were dipped platinum and were stuffed in Beyonce's twat.....way too fucking exspensive
this sux camel dicks
  • Who's Online   0 Members, 0 Anonymous, 1188 Guests (See full list)
