Just divide the width of the port window by the height if it gives above 9 the surface resistance of the port is going to be too high, it's a rule of thumb though, it can cause about the same effects of low port area: lost efficiency and probably port noise, just letting you know so that you bear that in mind in future designs.
For now check the rest of your system as indicated my previous post.
