Box design for Dodge Ram
Max Dims in 98 Dodge ram 1500 5.2 ext cab seats removed.
50 wide
21 deep
30 tall. could go taller but want to see out back lol.
Port Sub facing Im not sure??? i had sub forward port passenger side but at these dims, up is the only option, maybe forward?
Big three in 4 Gauge
New OEM 145A alt
Soon to upgrade Batt. Maybe largest kinetik/ XS ? Add another matching batt. to stabilize voltage.
AMP T500 bdcp 800w @ 1ohm
Subwoofers
Sundown Audio E12D4 Two of these
Specs on sub
Fs35.8hz
Qes0.56
Qms6.79
Qts0.52
LE1.85mH
VAS47.6L
BL15.4NA
Cms0.13MM/N
Mms156.6Grams
Sens. n/a 1w/1m
Xmax 12mm one way linear
RMS400w
Displacement 0.12ft cubed
would like input on tuning frequency please? 28, 32, 35??? i listen to decaf, bass mekanic, lil wyte, jeezy, classic rock too but i usually turn amp wayy down lol.
Thanks All
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
Ok so here is a suggestion subs up/port side:
Enclosure Specifications:
Fb = 34.5 Hz
Vb = 4 ft^3
External Height = 19 in
External Width = 40 in
External Depth = 15 in
Port Width = 13 1/2 in
Port Height = 4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 40 x 15
Left & Right Sides =
Side 1 = 12 3/4 x 13 1/2
Side 2 = 16 3/4 x 13 1/2
Front & Back = 40 x 16 3/4
L Port Internal Assembly Parts:
21 3/4 x 13 1/2
Assembly guide (generic dimensions):
4" of clearance in front of the port.
Any changes, comments or questions let me know.
thanks for the build sheet i just dont understand what the port orientation looks like inside the box and were the corner pieces and bracing should go so that the sound waves dont unload properly how do i see inside that sketch and stuff?
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
well it said your width was 40 and the port is 23in long. and its 3.75in fat, you can picture it in your head!? :discostu:
in a million, trillion, kabillion years,i would never play that song in my ride. I don't care if its clipped or not LOL. I feel like my nads got clipped after playing this for 15 seconds just to see what it was LOL.
No thanks bro. Not into it.
well it said L port, is that considered a L port? and since the port wall would be behind one of the woofers wouldnt that make the enclosure unload improperly?
Also i was wondering about the 45's if i should orient them vertical or horizontal.
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
scoot the subs to the left and closer together
or, just do like you said, and port it out of the top and make a L-port
It's a slot port but not a "L" as it does not turn is just a single piece of wood across the bottom of the box. If you are overly concerned do a front to back crossbrace in the center.
Loudest setup in that truck probably won't be a box designed like that one. Port up subs up is where I would start.
hell yeah subs up port up. i like that idea!! JOEX you sketch A design subs up port up and show me a cut away view please? I want the loudest setup like clean sierra suggested hmm... go figure lol
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
