half din/single din voltmeter
Im trying to find one because i have a half din slot open and it didnt come with a cover. or even a voltmeter that fits in between it. im just out of ideas because im not amazing at fiberglassing so then it probably wont look as good as i want it too. any help is appreciated
Vehicle: 2008 Mustang V6
Exterior: Blacked Out Taillights, Turn Signals, Side Markers-Black 18x8 Enkei ls5-6000k HID's
Interior: Blue LED Strips with Module for Music-Hardwired Beltronics RX65 with Blue LED and remote button
Sub: 2 10 inch custom subs
Amp: Hifonics BRz 2600
Wire: Knu 0 gauge
Headunit: Kenwood kiv-bt901
Damplifier: Fatmat Rattletrap
Electrical: Stock Alt/Stock Battery/Big 3
and the reason for that would be?
Wire: Knu 0 gauge
thanks for the help man... :nea:
Wire: Knu 0 gauge
just cut a piece of black hard plastic to cover the din then find a small voltage meter cut out the hole for the voltmeter hot glue it in place then mount it to the din.
that was option numero 3 haha. but yeah i have thought of many things. i gues ill probably try and fiberglass one unless i can find a tsunami rds9100
Wire: Knu 0 gauge
some.of the audiocontrol epics have volt digital volt meters in them
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
or you could put 2-3 meters in there and wire one to you front battery, one to your battery bank, and the 3rd if you can fit or choose to do 3 you could wire to your sub amp. then you would be able to wath the voltage through out your entire car. i think one at the front battery and 1 at the battery bank is enough though.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1094 Guests (See full list)
