TylerParrish Posted July 21, 2012 Report Posted July 21, 2012 A little bigger than to spec, but i find it likes a bix that size. Sub inverted of course. tuned to 33 Hz (because bitches love <33) ;P Lets see how it goes. Feedback please? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
TylerParrish Posted July 21, 2012 Author Report Posted July 21, 2012 is it a decent box? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Joe X Posted July 21, 2012 Report Posted July 21, 2012 Your ports may be to close to the side wall and you didn't fill in the sub displacement box which is 0.15 cubic feet.
TylerParrish Posted July 21, 2012 Author Report Posted July 21, 2012 How far should they be from the sidewall? and it's going to be inverted What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
SilveradoGoesBang Posted July 21, 2012 Report Posted July 21, 2012 Port needs to be the distance in diameter it is away from the wall. For say a 6" port needs to be atleast 6" away from wall "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
Joe X Posted July 21, 2012 Report Posted July 21, 2012 Port needs to be the distance in diameter it is away from the wall. For say a 6" port needs to be atleast 6" away from wall Well then there's a small negative displacement.. and the distance should be 4" from the side wall, you can either run the ports partially external or do the enclosure a bit wider.
TylerParrish Posted July 21, 2012 Author Report Posted July 21, 2012 Partially exte Port needs to be the distance in diameter it is away from the wall. For say a 6" port needs to be atleast 6" away from wall Well then there's a small negative displacement.. and the distance should be 4" from the side wall, you can either run the ports partially external or do the enclosure a bit wider. partially external it issss What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
