ok guys heres the deal. i have a 200 amp singer alt that runs at 12.3 volts at ilde ya i get it its a HO alt i understand so i talked to Mike and got set up with a smaller pully but now my problem is that my belt is to long its a double sides 6 groove serp belt at 48.25 inches i need it to be 47.25 inches anyone know where i might be able to buy one???? please help!!!
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
I'm having the same problem right now. I have tried 3 different length of belts and none of them got the alt over 12.4Volts even above idle. I'm sending mine back so he can test it and see what's going on. O'rielly has been good for getting belts. I've gone in and told them what length belt I need and they go get it for me. And if it doesn't work you can bring it back with your reciept and get your money back.
2001 VW Passat Sportwagen
Alpine ICS-X7HD
DC Audio 5K
SSA 15" XCON
Tantric Sounds 6.5HD's, Sundound Audio SA-6.5CS
Incriminator Audio IA6.4
XS batteries, KnuKonceptz wirez, Second Skin
have you checked at a place that sells gates ? because that would be the first place i would inquire .
O'rielly sells Gates belts.
Alpine ICS-X7HD
DC Audio 5K
SSA 15" XCON
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
thanks for all your help ill look into all of these thanks
you cannot gain volts from changing the size of belt. i put a smaller pulley on my alt and now my belt is to long so if i shorten it up it wont touch.
BIG 3
RF T400.4
all stinger wires
" you cannot gain volts from changing the size of belt."
Was that directed towards me? After talking with Mike, he told me it might be belt slipage that was the cause of my alternator problems, which seem to be the same as yours. Mine would not put out higher voltage no matter what rpm my truck was at, did your alt put more out with higher rpm's? If so, then it probably was the pulley and I'll shut up. If not you are having the same problem as me. I wasn't trying to call Mike out or anything. Let us know of you get it figured out.
Alpine ICS-X7HD
DC Audio 5K
SSA 15" XCON
