ok so heres the max dimensions that I can work with..
what u guys think ?
Edited by OrzechNewJersey
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
i know it looks small but idk the other way ..
If your max dims are 16 x 34 x 23 then about 4 cubes is you can have. (would need to declare the subs displacement of 0.32 cubes).
torres says 5.86 - 2x 0.16disp so i got around 5.5cuft
I just checked and they recommend 2.5 cuft for single fi q 12.. so maybe I shouldnt go over 5?
You are looking at the gross volume, look below to find the net volume, that is the one that specs the box it reads above 4 cubes but when you enter the driver displacement you will get about 4 cubes.
oh yea.. I see now..
I will stick to this than !
and I still gotta think off how to cut all the stuff since torres doesnt include the port pieces with my port size..
I will update the above suggestion to fit 23 deep instead of 23.5". Just a minute.
Ok here is one like the above but 23 deep which is your max, managed near 30Hz and good port area:
Enclosure Specifications:
Fb = 30.25 Hz
Vb = 4 ft^3
External Height = 16 in
External Width = 34 in
External Depth = 23 in
Port Width = 4 1/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 34 x 16
Left & Right Sides = 20 3/4 x 14 1/2
Top & Bottom = 34 x 20 3/4
L Port Internal Assembly Parts:
Front to Back = 16 5/8 x 14 1/2
Extension = 13 x 14 1/2
the total net volume includes the 45 corners ?
