hey guys'
This weekend Im gonna build enclosure for 2 fi q 12's
dimensions
34x16x20 a lil bit over 5 cuft without displacement
I wanna tune it to 30hz with round port and I just wander where I can get one?
torress says that I need one port 12" long with 6" diameter. port has 0.21 cuft
thanks !
edit: Maybe I should go with bigger / smaller port ?
Edited by OrzechNewJersey
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
hey guys'
dimensions
thanks !
On those dims about 3 4" port to the side would do but port area may be only sufficient, Slot ports are the way to go when aero ports can't provide what you need.
I was thinkin about aero ports to minimalize the "port sound" i might be wrong but thats what ive read before
If your port is big enough and you round your port walls in and out you can cut out the port noise.
I dont remember exactly now but port tuned to 30hz with 5cuft gonna 4 inch wild and 10 inch long not sure
Well aeros on the side maybe, this can be done going a bit over your max dims:
Enclosure Specifications:
Fb = 30 Hz
Vb = 4 ft^3
External Height = 16 in
External Width = 34 in
External Depth = 23.5 in
Port Width = 4 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 34 x 16
Left & Right Sides = 21 1/4 x 14 1/2
Top & Bottom = 34 x 21 1/4
L Port Internal Assembly Parts:
Front to Back = 17 x 14 1/2
Extension = 14 x 14 1/2
Ur dimensions are very similar to my current enclosure which i got with my p2s.. And im sure they will do much better in bigger enclosure cause they sound much lower with the trunk open..I was thinkin to make it at least 5cuft or more since they recommend 3.5 cuft for single fi q 12...
Yeah you can put them in 5 cubes net is just that I just went over your 34x16x20 if you have more tell me so and I will make it bigger no problem.
Im gonna measure the maximum dimensions today when i get back from work.. Thanks!
  • Who's Online   0 Members, 0 Anonymous, 609 Guests (See full list)
