As said above you should have a .1v difference max. This is more often than not a ground issue. Fix your grounds and see if that helps.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
the voltage on my epicenter is always lower then the amp. when i test voltage with a dmm the front battery charges at a higher voltage then the ones at back
front battery 14.9 back batteries 14.6, must be the wire resistance
Yeah your right because my hooked the volt meter to the batt under to hood and it reads 14.4 and at the back it reads 13.5. I guess by the time the current reaches the volt meter its one through lots of wire resistance.
well first you have to know where the wire is connected to. its the amp were its important, my epicenter is wired to the ignition source so thats why it reads less then what the battery really has.
need to know what kind of meter. i'll state again, that some meters have to be adjusted
its an Equus 6268, pretty basic. It was on sale.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
