start with big 3 in 1/0. a lot of grounds, and 2 pretty large AGM batteries from a respectable company.
edit: is this for daily or comps or both? music or tones? bass race or db drag? all that matters when choosing an electrical to suit your needs
big 3 is already done in 1/0awg kicker hyperflex
its going to be for mostly daily, but also able to put up good numbers
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
start with 2 big batts. one under the hood. one in the back. add a 2nd in back if needed. then a H/O alt if needed.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
well with a h/o alt, i was thinking about getting a 300a for a bit of overkill to try and cut out the necessity for extra batteries,
but i wanted to push 3k-3.2k to a 15" XL M2.
is that a plausible concept?
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
then do H/O alt first. then add bats!!
BMW M340 xDrive
well im just wondering if that would work to do a 300a alt and not need batteries lol
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
you will probably still need at least 2 bats
BMW M340 xDrive
