No, you want to set the sub sonic filter at the lowest frequency your sun can handle. For my dd 12 I have it set at 25hz I believe. It all depends on your particular sub!
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
I think the best way to find this out, is to run your setup on a TL and see where you start to roll off with playing frequencies, and set your SSF where you roll off.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
no. you set it a couple hertz below your box tuning. frequency response listed on paper has nothing to do with the subsonic filter setting.
Same how I do it,... 3-5hz "or so" below enclosure tune......
So 30hrz should be fine then. I don't have a filter on my amp so I have tou use those fmods. They only have a 20hrz or 30hrz cut off so I think I will be safer doing the 30hrz ones.
what amp do you have
Subs/Amps: TBD
