im going to be running an audioque 750 at 2 ohms but might bump up to 1 ohm soon. im ordering a new wiring kit and am torn between 0 and 4 gauge. any suggestions? btw im not going to add any more power (amps) for a while
Edited by basscherokee
2001 vw gti
2 hds212s
4.75 net tuned to 34hz
audioque1200 wired to 1 ohm
nvx 0 gauge to the back
kinetic khc 2000
kenwood deck
since it uses 4 gauge. use 4 gauge.
you're not gonna have enough power for the l7's though
That's alright I'm only going to run one for now but I just wanted to know if it would run fine on 4 gauge
2001 vw gti
2 hds212s
kinetic khc 2000
kenwood deck
It will work just fine, however something does concern me. You said you may drop it down to 1 ohm. How do you intend to do that? Your sub will not wire to 1 ohm, you'll have to get a second to run a final load of 1 ohm. In that case, the 750 isn't gonna get it done.
that amp will never need more than 4 gauge wire.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
run the 0 then disto it to 4 gauge at the amp.
Run zero gauge to the back and hook it to a distro block and get a small length of 4 guage to the amp. Once you get to bumping that bass your going to realize that your speakers suck at keeping up with the bass and your probly gonna want to get a 4 channel to get them louder. I've been there and done that in my Cherokee. Just make sure to fuse your wires after the distro block.
1999 Jeep Cherokee SportLifted on 31'sPopcorn Sounds AX6000.1 w/ AA 500.1 "THE F1X" board4 Obsidian Audio OA15's
C pillar wall @ 29hz
^^^work in progress^^^
i actually have a second sub and will run it at one (i know super under powered) but my next plans now will be to get a second 750.1 and strap them for 2 ohms on 2 new subwoofers in the future
just ordered 0 and im doing this :good: thanks guys for the imput
2001 vw gti
2 hds212s
kinetic khc 2000
kenwood deck
