Ok to build wall on folded seats and with headliner in?
Y not just 1 18 and your 2kw below the window line should beable to get 150 with that
with 1 18, on 1600 (not including voltage drop which is reallly bad right now. i can only hit 141.9...on music
then beef up your elec before you even consider adding more power, your getting bad voltage drop on 1600, what do you think will happen with 5k
Used to have a loud truck
2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq
2013 F-150 limited, MPT Tune, leveled on 35"s
if you do decide to do a cpillar wall you should have around 17 cubic foot, you may have more or less if the grand cherokee is bigger or smaller than a regular cherokee
against the door meaning inch. half inch even. ill post a video in like an hour. . . box specs are 6 net cubes. tuned to 32hz. double baffle. sub up port back.and its at the window line. again ill post a video about an hour and about the voltage drop. why the money im getting a HO alt and some batterys so thatll clear that up
17cubes of what? space from the rear seats?
from the rear seats to about 2 or 3 inches before the hatch
  • Who's Online   1 Member, 0 Anonymous, 1089 Guests (See full list)
