what amp is the right one?
that209kid
im planning on starting my first build, its not going to be fancy or for competition, but only for good sound. im getting 2 Rockford Fosgate P1s8-12 just to start off in a bit.
my question is: should i get 2 separate amps (1 for each sub) or 1 to power both?
brand names and models could be useful.
thanks.
the one and only
Run one amp, as that would be the easiest. And if I were you, I'd get an amp that has two channels so you can bridge the channels to get the most output you can at 4 ohms. 2 8 ohm subs will wire to a final load at the amp of 4 ohms. P1s won't take a lot of power, so you can get an amp like a Fosgate P5002 and call it a day.
P.S. A box that is built well and designed well, will be the best way to ensure you get the most out of your subs.
i like the way this man thinks
thanks that was good help, i didnt know what to get. you are a life saver.
the one and only
  • Who's Online   0 Members, 0 Anonymous, 1008 Guests (See full list)
