Semper Posted August 4, 2012 Report Share Posted August 4, 2012 It scales from -15 to +15. I currently have it on 0, should it remain on 0 or is this something I should contemplate on turning up or down. New Setup; H/U; Pioneer DEH-80prs. Wiring; 2 runs of 2/0 OFC & Big 3. Subs; 2 D1 DC Level 4s. Monoblock; DC 3.5k. 4 Channel; JBL GTO1004. Highs; Vifa NE25VTS-04. Mids; Aura NS6-255-8A. Alt; 160a. Batts; Optima, KHC1800. Link to comment Share on other sites More sharing options...
Mario928 Posted August 4, 2012 Report Share Posted August 4, 2012 max 15 and set it with dd-1 Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
Mario928 Posted August 4, 2012 Report Share Posted August 4, 2012 You set your sub level to the highest so that you get your max output. For example if your HU is a 2 volt pre-output then you will get 2 volt if you set it to 15 and all the other setting to flat. Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
