orion hcca 15.4 system help!!
i just bought a hcca 15.4. i need help with the size of the enclosure, what amp would best work, and anything else that would help me get the most out of the sub. i drive a 97 2 door cavalier. so i have to build a custom box to fit in my trunk. the trunk is roughly 32"W, 24"L, 18"T. i could build a box to fit but i know if i got the right dimensions for a box it would sound better. i also don't know what amp i should get. i was thinking a rockford t1500. i don't need a super loud system so i figured it would probably work. anything else that would help me out would be much appreciated.
you can do it for sure. you have a total of 8 cubes to work it.
I would suggest 3.25-4cubes volume for that sub you selected. I think that amp would be fine but the sub won't see it's full potential. ported or sealed?
If you don't want a super loud system then I think you'll be surprised at how loud your setup will be.
i think an http://www.audioque.com/AQ2200D-Amplifier_p_31.html would be a good pick for that sub. and around the same price as a T1500.1 but more power
WARNING: I speak 4 languages, profanity, English, sarcasm & real shit
2003 ford explorer
2 RF T1 D4 15s in a 6.8 cubic ft box
1 T1500.1bdcp
250amp ALT by Mike Singer
2 runs of 0 gauge
3 yellow tops
Here is a suggestion for the box on rated power:
Enclosure Specifications:
Fb = 34 Hz
Vb = 3.65 ft^3
External Height = 17 in
External Width = 32 in
External Depth = 21.5 in
Port Width = 4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 32 x 17
Left & Right Sides = 19 1/4 x 15 1/2
Top & Bottom = 32 x 19 1/4
L Port Internal Assembly Parts:
Front to Back = 15 1/4 x 15 1/2
Extension = 9 x 15 1/2
Assembly guide (generic dimensions):
Any changes, comments or questions let me know.
i'm planning on making the box ported. i think it'll sound better. i have 4 gauge wire ran in my car right now. should i go to 0 gauge? would my single battery be enough? i've never dealt with anything with this much power involved. so i really appreciate the help.
if i was you, i would get some 0 gauge, and the biggest XS battery you can afford..
and i mean some good 0 gauge, not some cheap stuff..
Edited by dkindle613
2003 ford explorer
1 T1500.1bdcp
2 runs of 0 gauge
3 yellow tops
http://www.darvex.com/store/pc/Sound-Quest-0-4-Gauge-Reducer-134p286.htm
and go to a local hardware store and get some smaller machine screws so the negative and positive adapter screws do not touch.. that's what i did..
2003 ford explorer
1 T1500.1bdcp
2 runs of 0 gauge
3 yellow tops
  • Who's Online   0 Members, 0 Anonymous, 1107 Guests (See full list)
