should i make a ground or use the rear strut tower for a ground? i was gonna use a self taping screw with a star lock washer and make a ground, its really thick metal, right beside the seat belt bolt. what do you guys think?
I always used strut tower..just sand it down to bare metal..I've never had a problem
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
just take one of the nuts off the strut tower and put the lug on that. thats what i've done.
this seems to be a very good ground but wanted to get some input..im gonna re-do my ground bc the wire and solder moves when i wiggle it
so the solder is not attched to the termianl so i assume that is not a good thing, so gotta fix that
after i saw the amount of resistance i eliminate when i do a negative run from battery to amplifier, there´s no way i´ll ever ground an amplifier to a bolt or the frame, just saying that´s a very nice choice you can make :)
How long was your ground from the amp to battery though?
E34 540iT/6
not much, maybe about 20" at the most in my explorer, and about 10" in my buddy´s kia rio, those are the 2 cars i´ve tested about this thing in the last couple of months, before that, i did test a few other cars and always gained :)
Edited by fecupe2001
  • Who's Online   0 Members, 0 Anonymous, 2779 Guests (See full list)
