A: don't use the relay.
B: take a dmm to that charger when you hook it up and make sure that it doesn't charge at over 15V. I had 3 different 12V Schumacher chargers that all wanted to charge at 16V+
A. Why? Wouldn't it protect my agm from being brought down by my stock battery?
B. I did it charged at like 14.8
Edited by BEEMDUB
Is it a relay or a solenoid? Or an isolator?
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Okay so it is a solenoid, you are fine using that, sounds like check your connections make sure you got tight clean connections.
Evo X build log
It is basically a giant relay, so make sure the ground is solid, I would go to the battery neg. You could check it with a DMM to make sure the coil of the relay is still functioning properly. Make sure ground and ign are connected, hook power to one side of the relay, check voltage at battery with car on (running), then check voltage at the battery neg and the open post on the other side of the relay, if it isn't the same at the battery then relay coil is weak and not letting full voltage pass thru the solenoid.
Edited by AMI CUSTOMS
Evo X build log
Hmm ok I did think that the coil could be weak but what do you think about this theory.. Heres how its supposed to be wired so on the big posts I had my battery 1 and battery 2 lead in 0 gauge, and on the ignition and ground lead I had some small ass like 18 gauge wire lol do you think that might the problem? I have 4 gauge wire I could use I just didn't think they needed some larger gauge wire because the posts are smaller than the battery 1 and battery 2 post
Edited by BEEMDUB
  • Who's Online   0 Members, 0 Anonymous, 1381 Guests (See full list)
