what is the difference between the regular coil and the spl coil on the sa line, i know they are lighter but do they also handle more power, and can they be used daily on music
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
The SA-10/12/15 SPL coil is simply an 8-layer flat aluminum USA made coil -- temperature handling is much higher.
Raises the FS of the woofer; hence being labelled the SPL coil.
They are fine for daily but have less bottom end and are ONLY sold on re-cones.
The SA-8 has an SPL coil in D2 / D4 that is also okay for daily -- it's simply a 4-layer CCAW coil to drop mass... the D1 SPL coil is for burps only (very tight) and is an 8-layer flat as well.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
