hey guys install my amp rack today but i wont get any juice into them and there is power runin through them i know cause i tried a buld on each checked the fuse box there was a blown fuse in the rado section change that and now the deck comes on but still nun from my amps epi and eqx any help would be greatful was thinkin its a remote issue not sure turn the key and the deck alone comes on and nun in the back does
Sounds like a problem with amp turn on lead. Did you by mistake run your Remote turn on wire to your amps from the Power antenna wire on the deck harness? It sounds like something simple to me and this is an easy mistake to make.
yea actually i ran it from the acc wire from the decks harness i have been usein it for a year now and only last week i decided to take of everything and build me a nice rack and right now nun wont come on only the deck does not even the capacitor in the back comes on and it uses a remote wire also but there is power at the cap
Get a dm and check and see if you have power at the head unit, then check at the amp, if you have power at the head unit and not the amp theres a short in the line. If theres no power in either one, your remote wire could be burned up internaly in the head unit. if you have power in both check your amp fuses, if theres no blown fuse on the amp side, you could have a damage remote on your amp. If for some reason it went into protect you can remove power wires from the amp for a few minutes and hook them back up and it posibly could reset.
Ive always been told to hook up positve befor negative to avoid shorting electronics out.
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
Your amps aren't turning on. You have no lights on the amps I assume. Power to those amps come from your power wire from battery back. Signal comes from HU, you have problem getting your turn on signal from your HU to your amp. Simple as that.
yea
thats it and it worked fine up until i took it off and put it back all the amps has lights a mtx thunder series and a hifonics zues head unit comes on fine but not the amp and processors
  • Who's Online   0 Members, 0 Anonymous, 922 Guests (See full list)
