help replacing ac compressor 2000 silverado 4.3
i need help replacing my ac compressor from a 2000 silverado 4.3
i already took the bolts out, but there is this part that is bolted ontop of the compressor, when i loosen the bolt, air comes out of it, just want to make sure that is normal, or how can i do it
the bolt im talking about is marked in a red circle below
thank you
im guessing you didnt evac the system, you should take the vehicle to a shop and have the work done as you obviously dont know what you are doing,
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
you need to get the r134a evacuated from the system and prehaps flush the system depending how badly the compressor degraded. after that if all your hoses check out and what not pull a vaccum on the system after you re install the compressor. then charge it with a gauge set to factory specifications
Edit: dont forget to make sure the compressor has enough compressor oil in it
Edited by bass_stalker
i would like to do that, but the compressor was so damaged, that the pulley got stuck, so when i turn it on the truck, it would have alot of friction that made the clutch and something else red hot, so they would basicly need to go to my house, or tow it, and i dont have enough money, i just want to put a compressor so it acts like a pulley, and when i have money, make the ac work
It's pretty obvious you don't have a MACS 609 certification so you shouldn't even be messing with it to begin with...
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
eh a little r134a in the hozone never hurt anyone. I dont see how its so bad for a user fixing his own ac pump/line vs a certified shop that does half ass work.
Example of my rear tahoe lines crapping out, and the same line on my tahoe leaking thru the hi pressure valve. The r134a was already out of the system due to the valve, and upon getting it charged i paid for vacuum testing. Needless to say it was recharged, lines where never checked for leaks and it all leaked back out in under a half day from the rear lines I didnt know where also bad at that time.
If the shop would of vacuum tested the a/c unit prior to filling they wouldnt lost the 2-4lbs of r134a that was put into the system without a proper vacuum test before hand.
edit, also when you reinstall that line you are taking off in the picture, make sure to use new o-rings on it. they are only a couple bucks, but you need to make sure it is sealed when you put it back on the a/c pump.
Edited by Audiofanaticz
Hey man you need to purge the system before you yank that shit off. Don't be like my buddy who got a face full of frion while swapping his engine.
Just loosen that bolt and let it hiss until its done but be careful. Just walk away while its emptying or whatever.
Nothing but old school!
01 Saturn SL1
Sony CDX GT500 H/U
Polk DB651 in front doors
Profile AMP121 on Polks
US Amps USA400 on sub
One 12" Cadence Ultra 6ohm
  • Who's Online   0 Members, 0 Anonymous, 1470 Guests (See full list)
