Ok so in about a hour I plan on ordering 2 obsidian audio dvc2 12s. They will be ran off a zx1500.1
Just trying to see if anyone is against them or has had problems with them, they will be seeing around 750rms ea.
Not sure if I should just get the dvc4s and buy a hifonics brz1200 instead and run them at proper power?
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
Ok then that's what I'm Gunna do then. Was just checking opinions. & yes I was going to wire to 2 ohms
just know the in the future if you buy another amp, your kinda kimited to 2 ohm amps, because 1 ohm amps are going to be way harder to find a lot of power at 2 ohms ( just sayin)
Won't be buying another amp for awhile. & can always sell this one.
These will be tuned to 32hz. Not trying to win comps but want them to get low and a little loud
Yea so just bought a 3.5 cube dual 12 box tuned to 32hz...& a shrunkien bt-120
A bit tight.. best of luck.
not really. 1.75 per sub is fine.
and OP, excellent sub choice. they'll probably beg for more power though ;)
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
I'm wondering if when I get them if I should just invert them so they get 1.91 ea..if that would make a difference
  • Who's Online   0 Members, 0 Anonymous, 2129 Guests (See full list)
