about to order 2 obsidian audio 12s...any objections?
Ok so in about a hour I plan on ordering 2 obsidian audio dvc2 12s. They will be ran off a zx1500.1
Just trying to see if anyone is against them or has had problems with them, they will be seeing around 750rms ea.
Not sure if I should just get the dvc4s and buy a hifonics brz1200 instead and run them at proper power?
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
Ok then that's what I'm Gunna do then. Was just checking opinions. & yes I was going to wire to 2 ohms
just know the in the future if you buy another amp, your kinda kimited to 2 ohm amps, because 1 ohm amps are going to be way harder to find a lot of power at 2 ohms ( just sayin)
Won't be buying another amp for awhile. & can always sell this one.
These will be tuned to 32hz. Not trying to win comps but want them to get low and a little loud
Yea so just bought a 3.5 cube dual 12 box tuned to 32hz...& a shrunkien bt-120
A bit tight.. best of luck.
not really. 1.75 per sub is fine.
and OP, excellent sub choice. they'll probably beg for more power though ;)
More box builds
I'm with captain stupid.
I'm wondering if when I get them if I should just invert them so they get 1.91 ea..if that would make a difference
  • Who's Online   0 Members, 0 Anonymous, 904 Guests (See full list)
