I don't think anyone's really "against" it per se, but there's a few reasons it's not really a good idea. The first, and probably most important reason, you can't control each channel's crossovers individually. You can only control them in pairs. This goes for the amp, your head unit, and pretty much any active crossover I can think of. So you would either need to go passive, or find some other way of crossing them.
So let's say you DO find a way to cross them properly. Well now you'll have to go mono instead of stereo. On most songs you won't be able to tell the difference, but there are a few songs that do utilize the left/right channels, and sometimes the effect is actually pretty cool and ends up sounding really nice. I guess this part is up to you, but it's not really the "proper" way to set up a stereo system.
If I were you, I'd just do (2-3) 6.5's and the tweets. Then if sometime down the line, you feel you need more midbass, you can get another amp and add the 8's (or other drivers) in the kicks, or redo your doors.
I was thinking about it over night and you guys made some pretty damn good points. I'll be scrapping my original plan and either going with 2 8" per door or 3-4 6.5" per door.
I left this information out but I already have 4 6.5" 4ohms and 1 8" 8ohms. I'll just have to decide which setup I want
Run the 6.5s and tweeters. What kind of crossovers do you plan on using?
x2
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
