boogie0410 Posted August 9, 2012 Report Posted August 9, 2012 I hooked up two 10s in a friends car in a three cubic foot box sealed on an aq 1200d and for some reason it sounds shitty but she didnt buy and radio so they got an rockford fosgate 360 i have never hooked up an radio with one of these can anyone help idk if they might need to be in a ported box or a bigger sealed box thanks
pa-pa-platypus Posted August 9, 2012 Report Posted August 9, 2012 put em in a ported box This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
boogie0410 Posted August 9, 2012 Author Report Posted August 9, 2012 like a three cubic foot tuned to 32
pa-pa-platypus Posted August 9, 2012 Report Posted August 9, 2012 2.5-3 cubes after port, woofer, and bracing displacement with bout 14-15 square inches of port per cube This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
boogie0410 Posted August 9, 2012 Author Report Posted August 9, 2012 i have no idea how to design something like that idk if someone else has had a sound system in a 2010 altima but the widest that it can go is 39 inches long
Joe X Posted August 9, 2012 Report Posted August 9, 2012 Here is a suggestion for a ported enclosure: Enclosure Specifications: Fb = 35 Hz Vb = 3 ft^3 External Height = 14 in External Width = 32.5 in External Depth = 20 in Port Width = 4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 32 1/2 x 14 Left & Right Sides = 18 1/2 x 12 1/2 Top & Bottom = 32 1/2 x 18 1/2 L Port Internal Assembly Parts: Front to Back = 14 1/2 x 12 1/2 Extension = 8 3/4 x 12 1/2 Generic dimensions assembly guide: Any changes, comments or questions, let me know.
