What's up everybody? Just got done talking to nick at Obsidian Audio and I'm ording 6 obsidian 18's this weekend. I will be doing subs up/port back in my tahoe. It will be b-pillar back. I've been playing around with the box design and it will be right around 30 cu ft. with around 420 sq in. of port. This is my first multi-woofer build and I really need help with bracing. What would be the best type of bracing I can use? And how do I calculate port bracing into the sq in. and tuning of the port? Thanks for the help! Also, can I get by with doing single layered sidewalls or should i do 1.5" thick all the way around?
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
They're running of a crescendo BC3500d at .66 ohms. So right at 4k watts for now. Hopefully upgrading to a bc5500 eventually.
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
i would double all around. i did a single on my box and it flexes like a mofo. then you could use 2x4s for bracing or, if you can weld, make some braces out of steel and paint them.
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
I don't trust myself welding. lol. But would you do angled 2x4's from side to top, or 2x4's straight up and down from top to bottom?
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
I'd use 1inch thick mdf. found at local lumber yard. Brace with threaded rods or 2x4's plus fiberglass and resin the insides and double baffle the top.
will try that, thanks. Never new lumber yards had 1" thick. but will 2x4's do as well as threaded rods? because 2x4's would be a lot easier.
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
threaded rod> 2x4's all day everyday.. all thread isnt all that hard to put on just takes a little time
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
if you wanna make it so the bottoms sits flush without have the nuts sticking through use 2 piece of half inch glued together and cut out a whole in the second layer for the nuts to sit..kinda like flush mounting a sub basically
power: dd m4
