What does adding an EQ really do (i only have a sub amp for now and my head unit has 5 volt pre-outs) should i get an eq? and what does an eq actually do? Sorry, never had any kind of experience with one
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
EQing is for correction of frequencies for rooms or different car environment, so when you have certain peaks or drips due to the shape of the car, correctly done, an eq can correct that for flatter response, which is what you're looking for.
The best eq I've seen so far is the Audison Bit-One(not cheap), where it has a mic and you play pink noise(20-20000hz flat noise), and eq through a computer to get the flatest frequency response possible .
Edited by Omega5002
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
the way i like to use a eq is cut frequencies and never boost .i don't like using eq's very much alot of times cutting or boosting 1 frequency creates a new problem frequency . my favorite eq i have used was in a vintage toshiba stereo receiver it was a 2 band parametric eq , sort of like alpine's 2 band eq's , but worked a lot better .
I'm about to put a mids and high amp in tomorrow and i have a sub amp, but i think what i have now sounds just fine for my intents and purposes, would an EQ make an audible difference?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
sounds better than the clarion http://www.onlinecar...totek_7007.aspx
couldnt do it, i refuse to use autotek after my personal experience with them
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Yes it will makr a great differance. Im the only.person i know that still uses eqs. I will never go withoit one
might get one to try it out, i could always just return it if i dont like it i guess (within the first 30 days)
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
