DC Sound Lab
Posted (edited)
so im planning on getting some level 4 12's running of a bc3500 when i get back from my deployment. but right now im trying to come up with some box designs for it. i was hopin to maybe get some advice on what to and what not to do.
as it stands im looking at putting them in a 3ft3 box becasue that is what dc reccomends. but i was wondering where an optimal tuning would be for them.
and any extra things i would need to take into consideration.
Edited by Maebros
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
I would tune based on what you like to listen to. For a daily system I dont think there is a magic freq that you should tune your box to. If you like alot of rap then go low, in the 30-33hz range. If you like more rock or country, something in the 35-38hz range would probably be good.
yeah i was thinking somewhere around 34hz. so i geuss that works.
any thing else i should take into consideration while designing the box.
If you are doing a trunk system, i would do a center port with a chamber on each side. Will give you a uniform look and avoid any possible loading issues
Good to know thanks
since its a later model civic like mine.. (2009)
you will have no problem getting 3 cu ft out of the trunk..
basically load the subs facing forward toward the cabin, and pushed all the way against the trunk lid. center port or passenger side port if you dont care about numbers.
its just me in my car so i put passenger side port so i load off my side of the car.
3500 watts your going to fall in love with the windshield flex.
i run a sk-1500 on 2 skar vvx 12"s tuned to 32.. and my windshield is pretty bad lol.
just a heads up since your on this topic.. deaden the trunk lid, and REAR DECK immediately!!!!!! they will be louder than your bass.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
i didnt need 3500 wats to figure that out as soon as i putthe sbs i have in there is was a nasty rattle so my rear deck got lined right away. might pull the hushmat up though and throw some SS on there.
  • Who's Online   0 Members, 0 Anonymous, 2028 Guests (See full list)
