What's the difference in a sub with 1 or 2 magnets and a sub with 3 magnets?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
do you mean like single stack, double stack and triple stack? if so, it is form function. it is all part of the engineering of the speaker. there is a certain amount of magnetic force required and whichever way is most cost effective or best performance is how they cut the magnet pieces. it has to do with throw of speaker, and a lot of variables that make the speaker go round
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
yes that's exactly what i mean, thank you, that's all i wanted to know
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Has to do with the geometry of the woofer design and how all the parts work together.
For instance, you may have a 200w rms woofer with a single slug. This is because at 200w, the woofer will only move a small amount. So adding more slugs would be a waste of money.
A larger woofer that handles 1500w rms can have 2 or 3 slugs. This depends on how thick the top plate is and how tall the coil is. Also what design are they using.
A SQ woofer will be underhung with a short coil and does not need as much depth in the gap as a SPL or ground pounding woofer.
So woofers also use a bump in the backplate to add depth.
Sometimes though, another slug is added to increase motor strength but this has shown to not help much. A good top plate and pole piece design can be the most effective when coming down to motor strength.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Good explanation.
