Run the speakers as i said in the post above with 2 sets of 8 ohm wired to 4 ohm and the 6 ohm on the other speakers.
So it would be 2 8 ohm sets on speaker A and 1 6 ohm set on speaker B cause you don't want to run below the rated ohm load on it.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
and thats each side right? so 2neg 2pos on a at 4ohm side, 1neg 1pos on b at 4ohm again or 8-16ohm?
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
alright thanks ill try it and let you know if that works. thanks for the help! :)
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Just finished wiring it. Seems pretty good to me so far. Still having some problems when it being way unbalanced but I just moved the slider to fix it
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
