Alright i will check if anything is loose or touching
But if that was the case wouldnt it just always be in protect mode?
Edited by Ryan929
if worse comes to worse, the amp is probably going bad. planet audio isn't really known for quality amps.
Yeah i know the amp isnt great lol and i was thionking thatt too if there was a problem somewhere or the amp was just broken and a piece of junk lol
Check all wiring cause something is grounding out, it might be at the speaker or it might be at the amp or on the terminal between the amp and sub and just make sure you have no strands of wire touching anything. If everything else checks out then your amp might be taking a crap on you.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
i had the same problem not to long ago. i had a strand or 2 of my power grounding out on my amp causing it to go into protect after vol 5 or 6
2004 cavalier 2 door 5 speedalpine cda-103skar pax 6.5s
power acoustik D1-6000power acoustic 4-2600soundquest 1/0 throughoutDC XL M2 18 walledstock altbig 3 donestock battery under hood, 1400cca 400ah semi battery in the trunk
  • Who's Online   0 Members, 0 Anonymous, 670 Guests (See full list)
