how do i get a straight inner port cut ?
i need some advice on how to cut a straight inner port cut ... it will be square but i just used a jig went slow but looks like shit ..
heres a pic
you can see here the inner walls are all sloppy .. this port is a throw away its the wrong size lol oops
alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers.
1. set is in the a-pilors
1. memphis mojo 2500 watt amp
1. rockford fosgate t2 15"
dual 2 ohm wired to 4 ohm . seeing 600 watts
1. realm audio 600 watt 4ch
heres a pic
jigsaw skills bro! some people just dont have em
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
try a circular saw?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
You need to clamp a straight edge or a level to the board you are cutting and use it as a fernce. Just don;t forget to figure in the blade witdth when clamping it in place
edit
dang ninjas
Edited by strangeduck
try a circular saw?
how would that work on the inside when it is a small hole ?
Take your time, or clamp a straight edge to the board to act as a fence.
i think i may have to do that .. i do it for that big cuts ... would a router work ?
heres a pic
lol damn i thought if i bought a nice jig saw it would be easier lol
I'd use a jig saw and a steady hand, but I have many years experience as a carpenter. The layman's best choice is a router with a plunge bit. Then you can clamp or screw 2x4s around the perimeter at the exact desired spot + offset and just go to town!! Easy-peasy!
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
try a circular saw?
didn't even think about what i said til just now, yeah bad idea
and jigsaw skills help, my dad was a carpenter so ive acquired my skills through A LOTTT of practice
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
but you could just cut and sand down to the point it should be at, what i do if it isnt just right
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 1821 Guests (See full list)
