For the heat part it creates heat because higher voltage means less resistance, example high voltage power lines like 400kv are like that because power companies lose less power to heat loss, its more efficient, when voltage drops resistance increases and cause lots of heat.
An amp is just a circuit, its stupid, it will do what its designed for, so say its designed to output a certain power, if the voltage drops it will try and pull more amps to create that power until it burns out. With it pulling more amps than its designed for and the heat increasing from resistance, amps die.
So, is it more efficient to run an amp at 18v?
*Rebuid in progress*
To a point. Some can take it, some cant.
Hammerdown... 1%
Think of low voltage like trying to run an engine without oil, it will run for a short period of time but eventually it will cease to work anymore and go up in smoke.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
To keep power output the same, the amp has to compensate by pulling more amps, which, like he ^^^ said, creates heat.
At least that's my understanding of it.
But then why does it do that?
Why what? Why does the amp try to keep output the same, pull more current or get hot?
P=V*I v being voltage I being current in amps and P being power in watts. If V drops I increases to keep the same power thus more current, current at a basic level, moving electrons generate heat. Wires get hot and that is bad.
So what is the point of a protector on a amp? Why does it smoke and not protect itself?
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
It will if it works correctly its more like the wires smoke, the amp should turn off if the voltage drops too low
