Aside from making less power... What happens when voltage is say into the 10s and 11s?
heat... more of it. Sometimes smoke, depending on how low it goes.
Edited by SoCaLBaMF
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
Ok, interesting!
Why does it produce more heat? What parts get hot and why?
To keep power output the same, the amp has to compensate by pulling more amps, which, like he ^^^ said, creates heat.
At least that's my understanding of it.
ninja noob moment.. ima just slide in here and basically say that its trying to give you the same output with less juice i would guess.. stressing it out..?
in a million, trillion, kabillion years,i would never play that song in my ride. I don't care if its clipped or not LOL. I feel like my nads got clipped after playing this for 15 seconds just to see what it was LOL.
No thanks bro. Not into it.
But then why does it do that?
Why what? Why does the amp try to keep output the same, pull more current or get hot?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Why does it pull more current? Like what physically goes on inside the amp to make that happen?
I'll try to explain, but if someone else finds some problems with this please correct me, it's been a couple of years since I studied this.
MOSFETS and Transistors have a set rail voltage they need to operate within. In our case, that voltage ranges roughly from 12-18V. So basically, when in that range, the signal is amplified and sent out to the load(subs). When you lower the rail voltage below the specified operating voltage, the components still try to amplify your signal at that same voltage. Since it cannot achieve that gain due to rail voltage, this causes more current draw, which in turn causes the components to grow hot, and :poof: you just met the magic dragon.
For the heat part it creates heat because higher voltage means less resistance, example high voltage power lines like 400kv are like that because power companies lose less power to heat loss, its more efficient, when voltage drops resistance increases and cause lots of heat.
An amp is just a circuit, its stupid, it will do what its designed for, so say its designed to output a certain power, if the voltage drops it will try and pull more amps to create that power until it burns out. With it pulling more amps than its designed for and the heat increasing from resistance, amps die.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
  • Who's Online   0 Members, 0 Anonymous, 9332 Guests (See full list)
