Here we go again... if its not louder this time then all that seal off the trunk hoopla is a load of crap lol
I ripped out the old "seal" it was tough, that ish was in there good. Not good enough according to the TL though.
Pics:
The Old
Acetone Cleaned and Prepped
False Floor Start
False Floor End: Coulda been better but itll work.
My friend and I workin on ze box
Test fitting
Resined er'
Sides Up
Fitted
Edited by P4killer_
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
More Test fitting
Sealing and Foaming starts
Its Hard to see but..
Thats it for now.
Tom Ill finsh sealing up the sides and dampening
And wire it up tomarrow
Is this sealed enough??>>>???
Opinions ideas etc Thanks
and obvi trimming the foam lmao..
Edited by P4killer_
Setup:
Xs D3400/ Xs XP3000
Yea i got some in the corner there but you cant see it... I was gonna do that around the box when i finalize placement after testing..
but anywhere else specifically???
Setup:
Xs D3400/ Xs XP3000
Ok Sooo Ive spent every day this week working on this project and Ive got nothing but inconclusive results..
Hopefully someone can help me sort through this.
First the specs:
SPL Box 2.8 net 6" aero port
Firing forward in the tunnel as shown.
Testing Procedures:
The box was tested at different depths in the tunnel every two inches.
Car off, external head unit
Batts charged to 14.5v, allowed to rest at 13.0v
Burp, record score
Charge, rest
move box 2" forward
repeat..
blah blah blah.
Loudest at the furthest position back..
So we burp:
143.7 @50hz
reset
144.8 @51hz!!! like who gains a full db from 1 hz?
we try to back that up and re burp that score = 144.4
reset
143.3 @52hz.. where did that full db go...
reset
try one more click on the volume..
143.3 @51hz.. WHAT HAPPENED TO THAT DB???????
needless to say we tried to eliminate variables
Changed the h/u.. similar results 143.3 ish
The amp clamps the same.. 1967w @ 1.4x Ohms Dropping from 14.3 to 12.0 car on.. consistently clamping a shade less dropping to 11.7x v with the car off.. i dont remember those exact numbers..
Sub nominal imp @ .5 all coils check out etc
The car is the same..
Port is the same..
Where did it go?
So ignoring that problem that neither of us can explain.. we began shortening the port.. current tuning was at 41hz peaking at 51hz
So by shortening the port and tuning closer to what it peaks at you should gain some..
I dont have the notes in front of me but needless to say we gain a tenth, shortened, gained another tenth
All said and done with tuning @ ~50hz burps a 144.8.. So great we got back to where we were.. but does that mean it could be a 145.8 once we figure out where that db went?
Either way the trunk is just about sealed as best as it could possibly be with out taping the box down after we finish testing and its not even close to the 146.3 they I did with the other box in the back of the trunk..
Now the whole point of sealing is to gain, which I havent in soooo many tries.. not even a tenth of gain and sooo much work went into this..
We thought maybe its the TL, on monday I might go and use my friends TL and use them side by side and see if mine is off, but why would it be,,? I mean wtf is going on..
anyway pictures:
Setup:
Xs D3400/ Xs XP3000
Setup:
Xs D3400/ Xs XP3000
and btw there is a shit ton of foam on the top the back between the tunnel and deck..sides are all foamed an sealed..
foam is like expanding through every nook and kranny possible.. so leaking is not likely at least to a point, but it should be almost perfect
Setup:
Xs D3400/ Xs XP3000
thanks btw for any and all helpage :P
Setup:
Xs D3400/ Xs XP3000
Weird results. Thats how this game goes though. Most intriguing is the lack of a gain from sealing it off.
Yea, i mean realistically for most people spending ohh idk 30+ hours easy and $150 in materials and gaining a few tenths especially for people who compete like my friend its time and money well spent.. a few tenths here and there is the dif between winning and losing.. now mind you i wasnt expecting a 49 or anything but maybe a 47 woulda been nice.. instead I lose several db..
oh yea and weirder still:
We burp idk like 144.4 at 51hz without a charge like we put a few burps on it at that point..
charge etc etc
Same freq and vol = 144.2 at 51hz LIKE HOW DOES CHARGING LOSE DBs!!!!!! like what in the hell is going on..
Thats why we started questioning the TL now that I think of it..
Setup:
Xs D3400/ Xs XP3000
