Stupid question but what is the PROPER way to safely remove an amp from your car? Do you remove the ground first? from the amp or the battery? also with positive?. It's been a while since I removed them, don't want to ruin anything. I hear so many ways to do it but there should be the right way. I was not sure if I could just take the Power and ground out of the amp terminals or if they had to come off the battery first. Same with installing them? Thanks
current flow is neg to pos. remove neg first then fuse then pos. I'm sure there are a thousand different opinions, my training points to this.
CARS
14 Sierra crew cab daily, Small build coming one of these days
69 C-10 fleetside in many pieces, won't be done till the end of time
Last car '12 Focus with build log
http://www.stevemeadedesigns.com/board/topic/165619-2012-focus-btl-15-crescendo-sundown-audio-control/
Remove neg at the power source first.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
This is the correct first step. too drunk to think straight. it is a pain in the ass if you have multiple batts though
also this should be the first step before doin pretty much any maintenance on your car.
Edited by Bship
CARS
all of us are saying the same thing except for one. go with the masses.
I just said it is a pain in the ass with multiple batts. it's still the proper thing to do.
Edited by Bship
CARS
I agree with aerickson here. After you remove the fuse, you really have nothing to worry about (as long as you're only messing with the amp). Easiest way to do it, and as long as you know wtf you're doing, shouldn't present any hazards.
I wouldn't stress about doing it the "proper" way. Just be smart about it and you'll be good. With multiple batteries, the "proper" way could honestly be unreasonable. Not to mention it'll reset the memory on your H/U and other devices.
Taking the - off the battery first is going to stop all power going to the amplifier. Then just unhook everything and put the - back on the battery terminal. This is the SAFE way to do it
So i remove the amps Ground from the battery first and then unhook everything else? Is that correct? To unhook my batteries grounds would take a very long time.
  • Who's Online   2 Members, 0 Anonymous, 1640 Guests (See full list)
