No Power to Headunit?
i just gotta ask....did u check to see if the fuse was blown?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
ohhhhh so i can run a wire off the yellow wire to that battery and then ill be good right?
"run a wire OFF the yellow wire"? The only thing the yellow wire should be going to is a constant power source...nothing else.
My car has the same issue, It's old and there is no factory plug in the dash. The fuse is good but the switch wont turn on the headunit. I ran a new wire to the battery positive from the yellow wire, and ran a wire from the red wire to a fuse that did shut off when the ignition was off.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
bakermanINC, i was saying since the yellow wire isn't long enough just connect more wire on it and run it to the positive terminal on the battery
yes...that will work. I thought you meant it was already connected to something, and that you were going to splice into it. That could end up bad.
hmmm, don't really know what to say then
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   1 Member, 0 Anonymous, 1935 Guests (See full list)
