*BYC* Posted August 21, 2012 Report Posted August 21, 2012 When you hook up a speaker/sub in series does it double the BL of the speaker??? And also when companies measure their t/s parameters, do they measure in series or parallel?
Ambassador of Bass Posted August 24, 2012 Report Posted August 24, 2012 I honestly have NO IDEA! haha All i know about Bl is that the higher the BL the louder the woofer plays but then it lowers Qes and Qts...BUMP? i'd like to know! Audi A6 Quattro Wangin' Wagon Pioneer Premier DEH-P5901B Headunit w/ IPOD control American Bass SQ5.25 in the Doors Compression Drivers and Horns under Dash 2 American Bass SQ475's for Mids/Highs4 American Bass HD 15's American Bass 500.1 17cuft 3/4" Double Baffle Birch Enclosure 240sqin port @38hz1/0 AWG Stinger big 3 under hood4 Runs of 1/0 AWG Stinger Power and Grounds Stinger Fuseblocks(3) XS Power D3100 Powercells120 amp AlternatorBlue Streetglow Underglow and Interior with Music InterfaceEscort Passport 8500 X50 HardwiredScanGuage II with voltage Readout
412 CVX Posted August 24, 2012 Report Posted August 24, 2012 tuned in for more Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
412 CVX Posted August 24, 2012 Report Posted August 24, 2012 good read http://www.speakerplans.com/page89.html Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
SnowDrifter Posted August 24, 2012 Report Posted August 24, 2012 yes, it does. But the BL is not the magnetic force, keep in mind. It is the ratio between electrical current and the magnetic/mechanical force. The actual motor strength is bl/re. If the re doubles by wiring things in series, then the bl will also double to keep the same ratio. Look at the specs for subwoofers: the 2 ohm coils have ~double the bl as the 1 ohm coils. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SnowDrifter Posted August 24, 2012 Report Posted August 24, 2012 yes, it does. But the BL is not the magnetic force, keep in mind. It is the ratio between electrical current and the magnetic/mechanical force. The actual motor strength is bl/re. If the re doubles by wiring things in series, then the bl will also double to keep the same ratio. Look at the specs for subwoofers: the 2 ohm coils have ~double the bl as the 1 ohm coils. Edit: or at least that's my understanding of it ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
