Fi Q 15" Ported Box 3.1 cu. ft. @ 32.5 htz I think
Hey guys need someone to check this over I am designing a custom ported box for a buddy of mine let me know what you think.
I have to leave for work now and will reply later let me know if I should change anything. Thanks.
And yes I know I am missing a side of the box I did that so you could see the port inside.
fisigggg.JPEG?raw=1 Crossfire_Car_Audio2_265_zpsd219cf51.PNG ablogo_zps4c550ed1.PNG?raw=1 download%204_zpsecsgajxi.JPG?raw=1 Audison-Logo_zps3f7b2a7f.JPG?raw=1 sundown_bg2_zps1d0951fc.JPG?raw=1 orionsmalllogosig_zpsf8d08612.PNG?raw=1 KaptionLogo_zps06c2a555.JPG?raw=1
I RREEALLY ANGRY WIT U PHOTOBUCKET. HAD TO USE DROPBOX NOW HOLYYYYYY.
Wanna ride bikes?
Quote
On 9/16/2017 at 3:28 AM, Jake Pace said:
Oh i know how a 12v system works I did take 3 years of electronics in High school hands on and some in college and also worked on cars in college an always got A's to B's in each class.
But oh well enough dealing with ppl who have probably not even lived as long as ive been into electronics!
On 7/8/2013 at 4:01 AM, Banshee421 said:
Do horns get low
i don't think that's a 3 common wall. it appears to be a 2 unless i'm mistaken. it's not touching the sides, only the bottom and the side opposite from the "missing" board are touching port.
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
You have a number of issues, use of 0.5 wood with that powerful sub may be a bad idea, keeping your external dims I would recommend this instead:
Enclosure Specifications:
Fb = 32.15 Hz
Vb = 2.9 ft^3
External Height = 20 in
External Width = 23.75 in
External Depth = 19.5 in
Port Width = 2 3/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 23 3/4 x 19 1/2
Left & Right Sides = 18 x 17 3/4
Front & Back = 23 3/4 x 17 3/4
L Port Internal Assembly Parts:
Top to Bottom = 15 3/8 x 18
Extension = 12 x 18
Assembly guide (generic dimensions):
But if you have space for a somewhat larger box, that would be best.
I did 0.5 for space. Max dims are 20x19.3x19.5. My BTL box has 0.5 and I have had no problems at all. Yes I wasn't sure about the common walls. This is my first custom box design sorry for the errors. Of course I would have done a normal slot box but I cannot go bigger then those said. That is why the port exits the side to fit between two backseat brackets. I will change the common walls to 1 and see what happens I am at work right now.
Wanna ride bikes?
Quote
Do horns get low
you only have 1 common port wall, and it could be way easier to build if you made the port mor like a standard slot port enclosure.
Well obviously, but my max dims cannot fit a standard slot port enclosure.
Wanna ride bikes?
Quote
Do horns get low
Fb = 32.15 Hz
Vb = 2.9 ft^3
Cut Sheet List:
Extension = 12 x 18
I appreciate your input a lot man but the max dimensions are 20x19.3x19.5
Wanna ride bikes?
Quote
Do horns get low
If you can picture just the top of the box. That is the "floor plan" I have to follow. I'm not sure I understand what you mean.
Wanna ride bikes?
Quote
Do horns get low
  • Who's Online   0 Members, 0 Anonymous, 1120 Guests (See full list)
