purplehaiz Posted August 22, 2012 Report Posted August 22, 2012 Just replaced my stock alternator with a mechman rhino 250. I'm idling at 12.6 volts. Is something not hooked up right or do the 4 batteries just need recharged that much? Because when I have it completely up it doesn't cut out
Casket Posted August 22, 2012 Report Posted August 22, 2012 Your PCM regulates voltage but you should not be that low, should be at least 13.8 . When i first installed my 300amp singer i was idling around 13.7 and would drop down to 12.6 with a decent load. Installed my bypass regulator and it sits steady at 14.8. Full load it does not drop past 14.3. Im sure somebody more knowledgeable will chime in. But with my small amount of knowledge and not knowing what equipment you have, i would guess your PCM is dropping the voltage EDIT: i would also check all of your connections, B+ and grounds etc for corrosion... Kenwood KIV-701Crescendo BC2000DDC Audio lvl3 w/ lvl4 upgrade, 18''6ft^3 @ 27hzMBquart ONX 4.125(2) PWX 6.5 (2) PWX 8(2) FT1300amp Singer with VCM @14.5Optima YT & D1200My Build Log every company has their niche market. hifonics has successfully captured the average ignorant teenage boy. Dont trip.. Ive never won anything in my life. Spite a 10lb cock and a bucket of balls at birth,......Yeah.. like i said, nothing in my life. meh, im cool with it, fuck it.
dohckiller808 Posted August 22, 2012 Report Posted August 22, 2012 what kind of car? my sequoia sucked balls at idle. mechman says the crank is small on a sequoia.
tdsa23 Posted August 22, 2012 Report Posted August 22, 2012 Same problem that I have a lot of foreign cars idle to low and have a small crank Call mechman up and let them know to see if there is anything they can do to help. XS Power D5100, 2 D2700s, & 2 D975s MechMan 220a Alt DC 5K Kicker 650.4 2 12 Ascendant Audio Mayhem's Pioneer DEH-P7200HD Rockford Fosgate 3sity.1 Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899 https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
purplehaiz Posted August 22, 2012 Author Report Posted August 22, 2012 It's a 91 Mazda Navajo. I did have a 300 amp fuse on it but a wire was loose causing arcing and melting. So it's wired straight. Is the lack of fuse the problem? I'm running 2 dc level 4 XL 15s with an ma audio 4000 watt amp. 4 batteries. Could it just be the batteries are so dead and the alt has to charge them?
dohckiller808 Posted August 23, 2012 Report Posted August 23, 2012 how is the voltage if you rev it up to 1k?
Ambassador of Bass Posted August 24, 2012 Report Posted August 24, 2012 You really don't need a fuse between the alt and the battery from my experience. I would guess it's low because the batt's are charging do you have any battery isolators installed btw? Audi A6 Quattro Wangin' Wagon Pioneer Premier DEH-P5901B Headunit w/ IPOD control American Bass SQ5.25 in the Doors Compression Drivers and Horns under Dash 2 American Bass SQ475's for Mids/Highs4 American Bass HD 15's American Bass 500.1 17cuft 3/4" Double Baffle Birch Enclosure 240sqin port @38hz1/0 AWG Stinger big 3 under hood4 Runs of 1/0 AWG Stinger Power and Grounds Stinger Fuseblocks(3) XS Power D3100 Powercells120 amp AlternatorBlue Streetglow Underglow and Interior with Music InterfaceEscort Passport 8500 X50 HardwiredScanGuage II with voltage Readout
fox_racin4 Posted August 25, 2012 Report Posted August 25, 2012 Rev your car to 2000rpm Wheres voltage at then? 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
TylerParrish Posted August 25, 2012 Report Posted August 25, 2012 Your PCM regulates voltage but you should not be that low, should be at least 13.8 . When i first installed my 300amp singer i was idling around 13.7 and would drop down to 12.6 with a decent load. Installed my bypass regulator and it sits steady at 14.8. Full load it does not drop past 14.3. Im sure somebody more knowledgeable will chime in. But with my small amount of knowledge and not knowing what equipment you have, i would guess your PCM is dropping the voltage EDIT: i would also check all of your connections, B+ and grounds etc for corrosion... what's a bypass regulator? it sounds very interesting. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
