Upgrade suggestions?
budah93
I like my boxes in the high 20's low 30's
There not as loud as say a high 30's
But if you box is at 35 now a bigger box on a higher tune will still get as low,
If you want loud then 37hz will do that
If you want sq then 28-30hz
If build daily boxes for theise up to 42hz
But my opinoin is over 37 you lose to much low end
In the end it's you box amd needs to suit your need and music type,
I listen to alot of rap so i'll prolly just stick to 35 hz cuz i just want it loud. I love your design except i'll prolly have the port vertical instead of horizontal
A 5x24" = 120sq"
To run the other way you port need to be 5.25x22.75
36w - 1.5" side wall and 6" for port leaves you with 28.5"
So you subs will have to be staggered in the box,
Also 35hz in your current box will go just a low as 37 in a bigger box
But I can redo with a lower tune if you want
how about you draw a pic and post it of how you want it, because none of the terms you use are common, and me and others have no idea what you are say
Here are my maximum dimensions. I can go 37 wide thats right on the wheels wells would prolly have about a 1/4" on each side. I would go 25 deep. Gives me about 7 1/2 inches to the back hatch. 24 high gives about a foot to the roof. Any idea's for a box. Prolly just gonna stick with 35hz and I want it to be very loud but i want to be able to listen to music not just do burps
  • Who's Online   0 Members, 0 Anonymous, 1379 Guests (See full list)
