Sean Evans Posted August 24, 2012 Report Posted August 24, 2012 Ford escort = bass chamber my friend has two l7s on a bd 1500 and my twelve messes with his ears
TylerParrish Posted August 24, 2012 Author Report Posted August 24, 2012 Ford escort = bass chamber my friend has two l7s on a bd 1500 and my twelve messes with his ears How did it mess with his ears? Did it touch em, blow it to his ears. maybe play with them? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
TylerParrish Posted August 24, 2012 Author Report Posted August 24, 2012 Its a retard when it comes to the meter. But a beast demo machine with a low tuned box. It is definately a beast demo machine, i wanna brag about when i had both my 12's in there....but it's hard to brag about my Mustang to well....OrionStang xD What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Sean Evans Posted August 24, 2012 Report Posted August 24, 2012 Like I said I don't want to hit below 130 I bet my other friend entering that I'd beat him he's running two ten inch Cvx's off of a 1000.1.....but he has them in a comp ported box
IH8PunkRok Posted August 25, 2012 Report Posted August 25, 2012 just a note for the guys with mustangs musically they are great. the cabin has a peak (at least the edge body style) around 44-45. this gives a secondary peak in the mid 20s. so with some good eq'ing you can be extremely flat and musical it was my favorite thing about the mustang always had a great sound -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
TylerParrish Posted August 25, 2012 Author Report Posted August 25, 2012 just a note for the guys with mustangs musically they are great. the cabin has a peak (at least the edge body style) around 44-45. this gives a secondary peak in the mid 20s. so with some good eq'ing you can be extremely flat and musical it was my favorite thing about the mustang always had a great sound love the new edge style, like i have, but what do u mean by a secondary peak? and it is extremely musical, it just took a little bit of testing the boxes and messing with settings, but i love the way it sounds. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
IH8PunkRok Posted August 25, 2012 Report Posted August 25, 2012 acoustics are all about octaves and wavelengths your secondary peak is going to be one octave above and below your main peak this is the point where your wave hits at about half the amplitude of your main peak. (read up on quarter wave theory) so imagine that you have a line from 20 to 100 (a relatively common sub bass range) with a main peak of 45, you have secondary peaks at 22.5 and 90 the line will look somewhat as follows small peak dip large peak dip small peak if you can visualize that you can really understand how it can be so musical. eq the 45 hz range down a bit and you have a decently full range of sub bass frequencies. now of course im strictly speaking cabin response here. box tuning and things like that are other ways to change the frequency response curve -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Nikitaaa Posted August 25, 2012 Report Posted August 25, 2012 acoustics are all about octaves and wavelengths your secondary peak is going to be one octave above and below your main peak this is the point where your wave hits at about half the amplitude of your main peak. (read up on quarter wave theory) so imagine that you have a line from 20 to 100 (a relatively common sub bass range) with a main peak of 45, you have secondary peaks at 22.5 and 90 the line will look somewhat as follows small peak dip large peak dip small peak if you can visualize that you can really understand how it can be so musical. eq the 45 hz range down a bit and you have a decently full range of sub bass frequencies. now of course im strictly speaking cabin response here. box tuning and things like that are other ways to change the frequency response curve Will this explains why I peak at 41hz but the low 20's are so dang loud.. 2007 M/T Honda Civic Coupe EX (4) Sundown Audio X-8's (2) Ampere Audio 3800.1's (3) Stinger SPV-44 Batteries (1) Mechman 240 3:1 Ratio 4th order sealed from the trunkTEAM NWSPLBest termlab scores to date in Honda trunk:151.7db legal (official) IASCA trunk 3 classBest termlab scores to date in my walled Subie:152.9db legal (unofficial) IASCA advanced 2 class155db outlaw
TylerParrish Posted August 25, 2012 Author Report Posted August 25, 2012 acoustics are all about octaves and wavelengths your secondary peak is going to be one octave above and below your main peak this is the point where your wave hits at about half the amplitude of your main peak. (read up on quarter wave theory) so imagine that you have a line from 20 to 100 (a relatively common sub bass range) with a main peak of 45, you have secondary peaks at 22.5 and 90 the line will look somewhat as follows small peak dip large peak dip small peak if you can visualize that you can really understand how it can be so musical. eq the 45 hz range down a bit and you have a decently full range of sub bass frequencies. now of course im strictly speaking cabin response here. box tuning and things like that are other ways to change the frequency response curve thank you for the explanation, guess its time to play around with some box tuning to see what's best in my car! What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
