scionicboom Posted August 24, 2012 Report Posted August 24, 2012 So the dd1, has been used on my amp to set the gains now currently I have one battery under the hood I plan on putting a new battery in soon so would I have to retune my amp with the dd1?
ROLEXrifleman Posted August 24, 2012 Report Posted August 24, 2012 no and I'll edit myself to say no if there is not a substatial increase in voltage. Rolex you sicken me. Just let me finish my pie ~ Juice
C-Fizzy Posted August 24, 2012 Report Posted August 24, 2012 Only reason you would need to retune your amp is if you changed head units. under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
Ambassador of Bass Posted August 24, 2012 Report Posted August 24, 2012 You should not have to unless you gain alot of voltage...possible but unlikely for example if your amp is doing idk lets say 1,250watts rms but you are at idk 12.5 volts now and you add another batt and go to idk 14ivolts then your amp will put out more power mayb 1500rms??? i made all of those numbers up...you get the idea...so short answer prob not but check your voltage before and after....if it goes up alot then jus recheck to be safe but you should be ok. Audi A6 Quattro Wangin' Wagon Pioneer Premier DEH-P5901B Headunit w/ IPOD control American Bass SQ5.25 in the Doors Compression Drivers and Horns under Dash 2 American Bass SQ475's for Mids/Highs4 American Bass HD 15's American Bass 500.1 17cuft 3/4" Double Baffle Birch Enclosure 240sqin port @38hz1/0 AWG Stinger big 3 under hood4 Runs of 1/0 AWG Stinger Power and Grounds Stinger Fuseblocks(3) XS Power D3100 Powercells120 amp AlternatorBlue Streetglow Underglow and Interior with Music InterfaceEscort Passport 8500 X50 HardwiredScanGuage II with voltage Readout
