p400.4 going into protect wtf?
BEEMDUB
Soo when I turn my h/u up to its max volume without clipping my amp goes in and out of protect sometimes numerous times and very rapidy..I had adjusted my rear and front gains on my amp to audible distortion and then backed them off..Well I just adjusted them with the oscope and while it pretty much fixed the problem it still flicked into protect for like half of a second a couple times...Why is the amp going into protect? the voltage isn't a problem does the amp detect distortion or something?
what ohm load did you wire the amp at?
you have three sets of speakers on it, which is why i ask.
The front channel has the 1inch component tweeters and the two st200's..All Tweeters have their own xovers...The rear channel has two 6x9s and two infinity 6.5s, no xovers theyre highpassed at 60hz
that doesn't help whatsoever....what do you have the amps channels wired to?
sorry bout that wrote that in a hurry before I left work...The st200's are 8ohm, the component tweeters and 6.5s are 4ohm and the 6x9s are 4ohm
Edit* theyre all in parellel too btw
Most likely your running below the 2ohm minimum load of the amp which is causing the amp to go into protect.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
what load in ohms is amp wired at? or what impedence are speakers and how do you have them wired?
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
there is your problem
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 1008 Guests (See full list)
