fli_noize Posted August 28, 2012 Report Posted August 28, 2012 My buddy has a couple of 15" Obsidian Audio subs laying around collecting dust so I figured I'd put them to use while I save up for my real system. The dimensions I'd like to work within are 39" W x 17" H x 19" D. These subs want a min. of 2.5 each ported, but a maximum of 2.5 each sealed. I'm wondering if I should build a optimum sized sealed enclosure, or a minimum sized ported enclosure? I've always been a fan of ported and would prefer this route but would still like to hear opinions. If I go ported anybody interested in doing a quick little design? All of my box building software is windows based and I don't have access to a windows computer right now. They will be running off a Crescendo BC2000D at 1 ohm. Specs for the subs below. Thanks in advance! Re: 4.0 Ohm Fs: 31 Hz Qms: 2.9 Qes: 0.76 Qts: 0.61 Vas: 81 Le: 4.36 mH BL: 18.18 SPL: 87 dB Sd: 856 cm^2 Mms: 321 g Xmax: 20mm Peak-to-peak: 62mm (2.45") Power Handling: 600 watts RMS Recommended enclosure info: Sealed ~ 2.0 to 2.5 ft^3 Ported ~ 2.5 to 3.75 ft^3 @ 28 to 32 Hz Cutout: 14.0" OD: 15.5" Mounting depth: 8" Mounting flange to top of surround: 1.5" Displacement: 0.19 ft^3 Bone Stock 2006 Dodge Magnum SRT-8
Skullz Posted August 28, 2012 Report Posted August 28, 2012 Don't do either as you won't get optimum results with it, get a pair of 12's in an optimum enclosure and call it a day. If your insistent on 15's then do one 15" in a proper enclosure and you'll be louder than a pair of 15's choked in that trunk. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
ZachG Posted August 28, 2012 Report Posted August 28, 2012 Don't do either as you won't get optimum results with it, get a pair of 12's in an optimum enclosure and call it a day. If your insistent on 15's then do one 15" in a proper enclosure and you'll be louder than a pair of 15's choked in that trunk. It's not a trunk..its a wagon. You could fit the 2 15s ported if you give more height cause you do have more available 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
IH8PunkRok Posted August 28, 2012 Report Posted August 28, 2012 a little hint ive been loudest sub forward port side did a 147.2 sealed on the dash with 2 AB XFL 15s subs up port back on 4k did a 148.6 sealed on the dash with 2 PPI crap 15s (one already blown) subs forward port side on 4k both of these setups had 2.75 cubes or less per 15 as well. musical setups -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
quakecitystudio Posted August 28, 2012 Report Posted August 28, 2012 I've got a design, it's a quarter wave t-line for a single 15 and box spec may change to accommodate - Surface area of speaker - 15" = (7.5) • (7.5) • 3.14 = 78.5 Width of box - .75 +.75 + 17 = 18.5 height of t-line to match speaker surface area - 78.5 / 17 = 4.617 or 4.5 inches Total height of box = .75 + .75 + .75 + 4.5 + 4.5 = 11.25 inches Total measurements = 39 length x 11.25 tall x 18.5 depth length of line = 39 - .75 - .75 = 37.5 inches Frequency - 37.5 • 2 = 75 in / 12 = 6.25 feet. 6.25 • 4 = 25. 1130 speed of sound / 25 = 45.2 hz Bass Music Producer • Photographer • Graphic Designer -------------- Deep Sector Boom...
fli_noize Posted August 29, 2012 Author Report Posted August 29, 2012 Thanks for the input. Like I was saying I was just throwing this stuff in because it's sitting around collecting dust and the BC2000 is just hooked up to nothing in the car with the fuse out. I just want something to bump some bass while I save up for the other goodies. I'll double check the height again I really don't want it to be too much above the rear seats. Only thing this build should cost me is $40 in MDF that's why I was even entertaining the thought. Future Plans will be a single 15 on 3-5k ported. Bone Stock 2006 Dodge Magnum SRT-8
fli_noize Posted August 29, 2012 Author Report Posted August 29, 2012 Accidentally double posted... Bone Stock 2006 Dodge Magnum SRT-8
