Jessica Posted August 30, 2012 Report Posted August 30, 2012 So, I hooked up my skar 1500.1 @ 1ohm today for shits and giggles. I have a stock 65a alt and a 4ga run to the back + a 6ga that was there from the last owner. That goes to a big ol' wet cell in the back and then i just ran a 2 foot run of 4ga to pos and to neg on the amp. I set the gains with the 0db tone and played some dubstep. I only dropped to 13.5 but mostly 13,8 from 14.1 (thats where my car runs hot). My grounds are 1/0 up front, one from alt case to strut and one from batt to other strut. and in back i have a 4ga from strut to batt. (yes, i know my wiring is a mess. I am just starting in front and working my way back and my regular setup doesn't need anything more than 4ga. Here is my question; So, am i just not seeing voltage drop because the 4ga can't handle the current? I don't believe that because the 4ga and 6ga both have 80a fuses, you would think one or the other would have popped. I am checking voltage right at the amp terminals. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
TylerParrish Posted August 30, 2012 Report Posted August 30, 2012 are you testing your voltage at the amp? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Guest Posted August 30, 2012 Report Posted August 30, 2012 if the wire couldn't handle the current passing through it, voltage would plummet you probably have a shit ton of impedance rise.
Jessica Posted August 30, 2012 Author Report Posted August 30, 2012 if the wire couldn't handle the current passing through it, voltage would plummet you probably have a shit ton of impedance rise. Probably, I clamped my old amp at 40hz and i was seeing 3ohms, i have no idea what it's like at other frequencies.Guess i should test it. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
fecupe2001 Posted August 31, 2012 Report Posted August 31, 2012 change your box I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
Jessica Posted September 1, 2012 Author Report Posted September 1, 2012 change your box It's in the works. I'm going to probably go with 3.8 cuft /net ,tuned to 32hz. I think i may have messed up a bit on the port on this one anyway and in my opinion is sounds a bit like it has too much port noise. I'm not really sure because i don't have that much experience with ported boxes. Wish there was someone around me that had more experience that could listen and point me in the right direction. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Omega5002 Posted September 1, 2012 Report Posted September 1, 2012 I heard those Skar amps are very efficient on electrical as well. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
JMZNeal Posted September 1, 2012 Report Posted September 1, 2012 drop your voltage leads into your amps - and + then tell us what the drop is... if they are on the alt side of the setup the wires aren't letting much current go through to the amp like previously said. I've heard you should always put them on your buss bar in the back or directly into the largest amp. JVC AVX-44 and 360.2 Subs: 2 RF T1 12s 1ohm mono off a RF T1500bdcp 80hz \/ in a 2.3cube 45hz slot port Mids: 2 O2 8's off a Punch 550.2 behind seat, 2 Image Cxs 6.5's and 2 ID XS 6x9s 80-3khz in doors on a T600.2 Highs: 2 ID CD.1 MH HLCD 8ohm off a RF 400.4 3khz /\
fecupe2001 Posted September 1, 2012 Report Posted September 1, 2012 change your box It's in the works. I'm going to probably go with 3.8 cuft /net ,tuned to 32hz. I think i may have messed up a bit on the port on this one anyway and in my opinion is sounds a bit like it has too much port noise. I'm not really sure because i don't have that much experience with ported boxes. Wish there was someone around me that had more experience that could listen and point me in the right direction. Post the box specs bro, but yeah i agree with kranny, pretty sure you have a lot of impedance rise, i had that same problem on the first box i built in the suzuki swift for 3 10´s, it sounded pretty nice and my voltage didn´t drop below 13.8v , i had a shitty port for sure since i didn´t have much room, well, i just changed the baffle on that same box and managed to fit a bigger port, voltage dropped to 11v lol I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
Jessica Posted September 1, 2012 Author Report Posted September 1, 2012 Well, somehow i click away after i had this typed up so i am doing it twice lol 34W 17H 20.5"D port 3.5W 15.5H 28" long (center port) I have a 1 1/2" dowel on each side top to bottom for bracing in the chamber. subs displace .28cuft Torres says its 3.65cuft with 54" port area and tuned to 34hz. Considering the power i figure that should be right on the money for what i need. I'm just not happy with the way it sounds. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
