gally Posted September 2, 2012 Report Posted September 2, 2012 So i has 4 Ground Zero Titanium subwoofers for about 2 months in my garage and i was thinking to do a wall.... subwoofer specs Model GZTW 38TX Diameter 380 mm / 15" Mounting diameter 358 MM / 14.09" Mounting depth 172 mm / 6.77" Voice coil 50 mm Runddraht / 2" Round wire Cone Coated paper Power Handling 500 WRMS Impedance 2 x 2 Ohm SPL 89 dB Xmax 14 mm / 0.55" Fs 23.1 Hz Qts 0.56 Vas 256,5 L / 9.06 cu.ft. Car is Opel/Vauxhall Corsa C I will post my max dimension to do a wall.....tune would be 34hz if it could be done i will need to do some modifications to my car first, so in the next couple of days i will post the max dimensions... is there any input or instruction on How to do a wall? thanks in advance 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
Cardboardcat15 Posted September 2, 2012 Report Posted September 2, 2012 What I did for mine was base it around how safely I could mount it into my car IE bolting it down. Once I found some good spots, I started a false floor and built on top of that. I'm sure there are other ways to do it though, that's just how I did it. My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
chrishova Posted September 2, 2012 Report Posted September 2, 2012 I was thinking of doing this in my Grand Prix, saw a couple of peeps in here do it... Any input will help! Pontiac Grand Prix GT400a Mean Machine alt. EIGHT DD 12''s on a DDz2DD vo 8''s,6''s,5.25''s&tweetsNorfolk, VAhttp://www.youtube.c...ser/ovnorfolkvahttps://www.facebook.com/groups/TheSPLSpot/473815915987218/?notif_t=group_activity#!/chrishovahttp://www.stevemead...__fromsearch__1[/color]
fox_racin4 Posted September 2, 2012 Report Posted September 2, 2012 When i walled my truck, i built the floor first, got it flat with 2x4s then 2 layers of mdf, Did the roof next the same way, For the sides i acctually glued/screwed the 2x4s right to the truck itself got ot flat, then did 2 lauers of mdf So basically the "shell" of my wall is the truck itself 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
gally Posted September 2, 2012 Author Report Posted September 2, 2012 i am planing to do a wall.....later this year or early next year....still undecided about it...but its tempting 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
gally Posted September 2, 2012 Author Report Posted September 2, 2012 anymore inputs on walling? 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
Kevin M Posted September 2, 2012 Report Posted September 2, 2012 anymore inputs on walling? Look at a bunch of the wall builds here to get more ideas. Floridaspl has quite a few too too. Using 2x4's makes it much easier. Esp. if you have a bunch of funky transitions. After you feel comfortable enough jump in with both feet. Experience is the best teacher. When I tore down my wall this weekend I could see where I needed improvement and what worked/didn't. Take it step by step and have a plan of attack. Overbuild. Before I thought of my wall as an enclosure; now I liken it to a bunker. Internal bracing is important. I thought I didn't need it, walls were 3" thick. (mdf and 2x4's) baffle was 1.5" I was wrong. Even on 1500 watts I had baffle flex. That shit isn't going to happen this time. That's my advice from one noob wall builder to another. 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle
