ClassicsWithSQ Posted September 3, 2012 Report Posted September 3, 2012 Ok so I have set up systems before sure they aren't top of the line but I have experience. Now I am making a system for my 1968 camaro so I want it to sound quite loud seeing as I'd like to hear it over the vehicle running haha. My question is I was wondering if I can run a set up like so; Two 2 channel amps and two subs both right channels from the amps to the right sub (one right channel to one of the voice coils and the other right channel to the other VC) and same deal with the left channels to the left sub? Any input would be much appreciated.
ToNasty Posted September 3, 2012 Report Posted September 3, 2012 Just get a mono amp and depending on the.ohm of the sub and amo combo , bridge them ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
BEEMDUB Posted September 3, 2012 Report Posted September 3, 2012 X2 alls you need is one mono amp man will make things much easier
ToNasty Posted September 3, 2012 Report Posted September 3, 2012 What subs are you.planning on running? And you might not need 2 either ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
ClassicsWithSQ Posted September 3, 2012 Author Report Posted September 3, 2012 I'd like to run two amps not only for a good look but power I was just wondering if it's possible and SA-10s two of them in a 1.27 ft3 ported box (2" wide port that is 25" long)
ToNasty Posted September 3, 2012 Report Posted September 3, 2012 You.can run 2 amps. Run one for the sub and one for the speakers. Theres just no reason for running 2 amps for 2 subs. And that box seems a bit small. And what is that box tuned to? ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
imnew59585 Posted September 3, 2012 Report Posted September 3, 2012 X3 you just need a mono amp, if you have one amp and you wire everything together down to 1ohm or .5ohms it will be louder then two amps only two reason why you would run multiples is because your mids and highs, or you got more then 2 subs
ClassicsWithSQ Posted September 3, 2012 Author Report Posted September 3, 2012 Should be about 38 hertz. Also I have 10 speakers in the cabin, 4 6.5" 2 way, 2 5.25"full range, 2 3.5" full range, and 2 4" mono speakers will one 4 channel amp be enough for all that?
ToNasty Posted September 3, 2012 Report Posted September 3, 2012 What amp and why dont you have tweeters? ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
ClassicsWithSQ Posted September 3, 2012 Author Report Posted September 3, 2012 Won't the full range and two way speakers be fine? if not I have some RF tweeters laying around somewhere and the amp is my dads old kicker zx650.4
