~500rms@2ohm amps
brandon9491
a 700 watt amp needs 2 fans in order to keep it from overheating...dont you see that as a problem with the overall design of the board?
how inefficient does an amp that small have to be in order to require 2 fucking fans for it to actually work? i'll tell you. very inefficient.
i've seen those things get HOT when not even playing anything.
the best defense is a good offense? maybe theyre protecting the amp from dumb asses who turn the gain and bass boost all the way up.
we must have gotten lucky and got a good amp, no overheating/protect issues. hmmm weird
the amp still gets hot even with those little 20mm fans. its more of a design flaw in my mind, than a method of protection against ignorant users. the protection circuit inside the amp is supposed to be able to sense and react when something has gone wrong that the user caused, like overheating. people didn't go to kenwood like "i have my gains maxed out and your fucking piece of shit amp keeps getting really hot and then protects on me." LOL.
last i checked, there are no fans on an audioque 3500 nor the sundown 3500. there are quite a few amps in the few thousand watt range that dont have fans. why? because they're designed well and the heatsinks are adequate enough to dissipate the amount of heat that is created by the internals.
wire your amp to 1 ohm and see what happens.
i would never feed 900 rms to a VVX unless you absolutely know what you're doing, clipping an running over rated will get them stinky FAST, I found out from first hand experience before i turned my amp down. Sorry for the continued threadjacking.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
buy me the dual 2 :doit:
MB Quart Fx1.600 does not do rated fyi, can do clean power yes but not rated. Try the RF T500bdcp
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
OP, the Kenwood being discussed is FAR from the best option here. They indeed get hot at 2 ohms, and won't go below 2 ohms successfully. If I were you, I'd look into an older Fosgate P6001, or 5002 that will do the power at the ohm load you're requesting.
Something like this:
http://www.onlinecarstereo.com/CarAudio/p_14327_Rockford_Fosgate_Punch_P6001bd.aspx
Or this:
I've personally run both those amps in the same build and they worked beautifully. I ran the 6001 to my subs, and the 5002 to my components.
http://www.onlinecar...ch_P6001bd.aspx
Or this:
both the links are the same
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   1 Member, 0 Anonymous, 931 Guests (See full list)
